I'm after some advice with replacing a PRT100 thermostat.
We've recently moved into a new property that has the following setup:
Potterton Suprima boiler in kitchen
Potterton EP2002 programmer in kitchen
Potterton PRT100 thermostat in the living room
There's also a tank in a cupboard in the living room that is connected to a small white box that is marked Myson Power Extra, and another unit that is marked Myson Compact CP53.
The thermostat on the tank is set to 50 degrees.
I would like to replace the PRT100 with a wireless thermostat. I'm happy for the receiver to sit on the wall where the PRT100 is, but I would like to move the new thermo unit to the hallway where it is cooler.
The problem we have at the moment is the living room warms up quickly and switches the heating off to the rest of the house leaving the upstairs quite cold.
I've read that it is fairly simple to replace a PRT100 with a Honeywell CM907, but is it straightforward to replace the PRT100 with the wireless receiver from a CM927?
The PRT100 is wired up as:
Red --> 1 (TL)
Yellow --> 2 (H)
Blue --> 3 (N)
Thanks for any help,
Steve
Red --> 1 (TL)
Yellow --> 2 (H)
Blue --> 3 (N)
Steve
