    Dismiss Notice
Replace top of gate post
Discussion in 'In the Garden' started by Jimbo, 19 Mar 2019.
  1. Jimbo
    Jimbo
    23 Sep 2002
    245
    Thanks Received:
    4
    Country:
    Hi all,
    I have a gatepost which never had a cap on it, as a result the top has rotted somewhat. To replace the whole post would be a royal pain, not to mention ruining the recent re-tarmacing of the drive.
    If the post wasn't set in the ground, a scarf joint would be sensible and relatively easy, but I'm not sure if that's the best approach in this case.
    Any advice?
  2. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,605
    Thanks Received:
    566
    Country:
    How much needs replacing? Are there any others that you need to match to?
  3. Sponsored Links
  4. Jimbo
    Jimbo
    23 Sep 2002
    245
    Thanks Received:
    4
    Country:
    It’s not much actually, the main reason for doing it is to stop the rot spreading. Perhaps 8 inches.
    However there’s a brace from the top of the post to the other side, so it needs to be strong enough to support the screwing/bolting of the brace.
    There’s no matching to any other posts needed.
  5. scbk
    scbk
    22 Dec 2012
    764
    Thanks Received:
    139
    Ross-shire
    Country:
    I would be tempted to scoop out the worst of the mushy (rotten) wood, fill the hole with preserver or oil, then fit some sort of cap over the top of the post.
  6. Sponsored Links
  7. Jimbo
    Jimbo
    23 Sep 2002
    245
    Thanks Received:
    4
    Country:
    @scbk Yes that was my first thought, however the bolts for the cross piece go/went through this part. I think I'll just do an in-line lap joint affair with a couple of coach bolts for good measure.
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
