Just wondered if anyone can give me some advise on replacing my old wc, it has a waste pipe going into solid ground. The existing pipe is quite old and i want to replace as much of that as possible with new pipe.
1. Is it worth knocking out some of the cement and cutting the pipe below the ground?
2. Is there a way to use existing pipe using a pan connector, if so will it 'hide' the old pipe as i guess it will be pretty mingin' where i have had to cut into the old pipe.
any advice will be gratefully received.
rob
rob
