    Dismiss Notice
Replacement ballast for 2 x 58W fluorescent
Discussion in 'Electrics UK' started by cjcoffin, 25 Sep 2020.
  1. cjcoffin
    cjcoffin
    17 Oct 2006
    56
    Thanks Received:
    7
    Cambridgeshire
    Country:
    Am trying to find a replacement HF ballast for a fitting believed to be a TLC MDEC 258 [https://www.tlc-direct.co.uk/Products/MDEC258.html].
    There are various ballasts for 2 x 58W fittings listed on line from third-party suppliers but they come in several different sizes and fixing centres. Neither TLC nor the manufacturer (?NVC) have been much help.
    Can anyone tell me where to get the _correct_ ballast for this fitting?
    TIA, Chris
  2. davelx
    davelx
    26 Sep 2006
    1,788
    Thanks Received:
    143
    London
    Country:
    If it was me, I'd get one of these
    https://www.cef.co.uk/catalogue/products/4108203-1-x-58w-h-f-ballast
    and if necessary drill new holes or whatever to mount it in the fitting. If you want a direct replacement then you need to measure the fixing centres and compare them to the data sheets for various units. I'm sure you can do that just as well as we can!
  3. Sponsored Links
  4. cjcoffin
    cjcoffin
    17 Oct 2006
    56
    Thanks Received:
    7
    Cambridgeshire
    Country:
    Thanks davelx.
    Turns out it was a Thorn Punch II fitting not TLC non-branded, they have the exact Tridonic ballast with 270mm fixing centres that you recommended so all good.
  5. fluorescence
    fluorescence
    15 Jun 2018
    185
    Thanks Received:
    22
    Country:
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
