Hi All,
Please forgive my basic knowledge, I will try and explain as much as possible.
I have a flat that currently has a hot water cylinder. Now there is no gas in the flat (electric only) and the cylinder appears to be a combi type (with the header tank in the top half of the cylinder) with an electric immersion. I understand that this is a direct type (as there is no boiler, just an immersion) and is vented.
The flat is currently being renovated and I have a few problems with the current tank as follows:
a) It is in a cupboard in one of the bedrooms, as it is a top floor flat with a humungous loft space above, i hope to free up some space (and get rid of the ugly cupboard) by moving the hot water cylinder to the loft
b) The current pressure is not enough for the new waterfall taps that i have bought for the bath which appear to need higher pressure.
c) Very few things require a hot water feed as the heating is electric underfloor, the dishwasher/washing machine are cold feed only, electric shower. The only hot water feeds are the kitchen sink, the bathroom sink and the bath. Due to the weird bathroom size/shape it has a custom bath that is 300litres!
My idea is to move remove the current cylinder and put in the loft a header tank, feeding a 90/100 litre cylinder (with immersion), feeding a 50/60 litre cylinder (with immersion) in series which then feeds the taps. the idea behind this is that the 50/60 litre tank will be the normally on cylinder for the bathroom/kitchen sink taps and then when a bath is required the 90/100 litre cylinder immersion can be turned on to give 150 litres for the bath.
My questions are:
a) Will moving the cylinder up in the loft (about 1 metre higher than current) give it enough pressure?
b) will the idea of putting 2 cylinders in series work?
c) If b) above will work, is it OK for the cylinders to be the same height?
Thanks in advance.
My questions are:
Thanks in advance.
