Replacement Radiator Bleed Valve Grub Screw (Air Bleeding)
1 Oct 2011
West Midlands
Hello everybody,
Second thread for me on the forum!
I have old radiators in the house (about 12-15 years). Single flat panel with fins.
Writing on radiator: BS 3528 and further on FEK 1 A.
Bleed System - The bleed screw, screws directly into the back face of the radiator.
Pictures are worth viewing.
We got a baby on the way for the new year! Expected Jan 1st!
I really do get that these 'might' be hard to find. But I will try, try and try. That is why I am asking any of you - could you please give me some suggestions or pointers, no matter how small?
EDT: I.e. I need replacements - where can I get some from, or even better - I am trying to create a solution to this problem (rounded bleed screws) - can anyone contribute?
Many Thanks,
SirLancealot.
:mrgreen:
There are three different threads that I've known about, but don't keep mental records of things like that! Your rads are relatively recent compared to some so you shouldn't have a problem.
Try you friendly local neighbourhood plumbing merchant. One which has been there for ages.
They should be able to produce at least a couple you can compare with.
Often they'll come in an insert which you won't need. As you have one to take with you that saves a lot of experimenting!
Radiator is in that condition and you have already removed it from the wall,I think it would be better idea to replace it compeletly with brand new one,the modern radiaors will emit more heat and are alot more efficient
