Hi everyone!
I was wondering if someone may be able to help. My partner accidently fell into the shower door and snapped the lower hinge (i presume the upper hinge has also been affected even though it still looks normal). The shower is a Roca Axis LF from 2013 and unfortunately it's discontinued so they were unable to help.
I was wondering if anyone knows where we could get replacement hinges that would fit the cut-outs already in the glass door, or another way to fix it? The glass is 6mm thick and the centre of the holes are 40mm apart on each side and 12mm diameter, with a horizontal alignment.
I've had a look online but haven't had much luck. Want to avoid having to change the whole shower unit if we can help it
I've attached some photos which i hope are helpful.
Many thanks for any help or advice you can give
