Hello,
I wonder if someone can tell me what i actually need for the following job.
I have an 8KW elec shower at the moment that needs to be replaced. The feed comes from the consumer unit and has no RCD. The feed is 6mm.
I want to put in an 8.5 or 9.5 kw shower and run a new 10mm cable.
Can an RCD be added to the circuit without replaceing the consumer unit which has re-wireable fuses? Should the pipes in the bathroom be bonded? They're not at the moment. Is the bonding a DIY job? The other work will be done and certified by a sparky.
Any help appreciated. I've has several different electricians telling me I need different things from a simple job to rewire the house!
Thanks,
Dave.
Thanks,
Dave.
