replacing a cracked tile
10 Feb 2007
Kent
Hi all
I have managed to crack a tile at the edge of the kitchen (its only a half tile.) I have also noticed that it, along with its neighbour have lifted slightly.
I would like to replace the cracked one- but I have no spare tiles
how possible is it that I can lift a tile up from under the washing machine and use that to replace the cracked tile.
Thanks in advance
12 Jul 2004
Surrey
remove all the grout be prepaired to replace 2 or 3 tiles with 1 sacraficial to allow access behind 2 others
soak in soapy water for a few days to soften adhesive select the best tile and keep the other as a spare
use white adhesive if natural stone tiles
or alternativly pimp a few tiles
http://www.nouvellesimages.com/Stickers
4 Mar 2010
Replacing a cracked tile first removing an unwanted fixture from a tiled surface. Breakup the tile with a hammer by using cold chisel remove the broken tile. Take a stiff putty knife scrape the old adhesive, and become relatively smooth, then level the surface for the new tile. Use tile adhesive and apply the complete back of the new tile, and also apply some adhesive in the broken tile place, and fix the new tile in the gap. Press the tile firmly all the corners for the level of surrounding tiles.
