Replacing a Danfoss HPV28 2 port valve
18 Aug 2008
Northamptonshire
Have a leaking HPV28 2 port shoe valve (with HPA2 Actuator) on my central heating system. From all the post I have read the recommendation is to replace it with a Honeywell but I am not sure which V4043 I will need.
Is the V4043 a shoe valve or a paddle valve? Does it matter if I switch from one to the other?
SPST or SPDT the Danfoss is SPST but the Honeywell site states that the 28mm only comes in SPDT
Direction of flow. This is not specified on the Danfoss but is on the Honeywell. I presume the direction of flow is away from the pump but want to make sure I get it right.
Thanks for your help
Aussie2
if its a central heating valve it will fit and work. however the threads on the valves may be different and the fittings may be male/female depending on the manufacturer, especially with a 28mm valve. some manufacturers inexplicably use both.
direction of flow is either by an arrow or by letters a and b stamped on the valve. "a" goes to the pump side, "b" goes to the outlet side.
