Replacing a double light switch
19 Feb 2007
Hi all,
I'm having a few troubles replacing a double switch, and was wondering if anyone could help me. Here's a brief overview...
The double switch controls the lights in the hallway and bathroom. I replaced the old plastic switch with a Volex flatplate by simply copying the wire setup from the old switch to the new one. Everything worked as it should, no problem there.
However, when I tried to screw the new switch into the wall, the metal box wasn't deep enough (it was only 15mm). So, I took it apart, removed the old 15mm box (with some regret as it's ruined part of the newly plastered wall!) and replaced it with a 35mm box (as I'd like to add dimmers at a later stage).
When I turned the power back on, I noticed that the hall light was permanently on. Flicking the light switch for the hall light seemed to do nothing, although the bathroom light was working without any problems. It was wired the same way as before, as I drew a small diagram.
I then proceeded to fiddle around with it and managed to blow my main fuse, which wasn't very clever.
The irony is that after the callout charge it would have just been cheaper to get a sparky round, but I'm adament this light switch won't beat me.
The set up is the following...
- I seem to have a red and black wire going into the common and L1 terminals for the bathroom light, and it's also earthed, so no problem there.
- For the hall light however, I have two brown wires going into the common, and nothing going into L1 or L2 - the two blue wires are just wired into a plastic connector (and there is also an earth attached to the metal box). I tried to wire the neutral into the L1 and that's what caused the loud pop, so I won't try that again.
Apologies for waffling, but this is really getting to me now. I don't understand the logic as to how one switch can have a live and a neutral, yet the other switch has not only different coloured cables, but a seemingly different setup.
If anyone can help me it would be massively appreciated.
Regards,
Shanksy5
One of the browns is a switch return to the light and should be in terminal L1 or L2.
Sounds like at some point somebody has wired in a new light and changed the switch from 1gang to a 2 gang. Had to have been done between 2004 and now
Sorry, just to check. One of the browns goes into the Common and one into the L1? So I leave the blue wires as they are (just screwed into a plastic connector)? Any chance I can blow anything up again?
Thanks so much, it's much appreciated.
Shanksy5
Shanksy5
You've got it.
The switch box is being used as a junction box, 1 cable will be L/N/E in (Live to common of switch, N to plastic connector block with the other blue conductor, E to back box terminal). The other cable will be L/N/E out to the light (Live from L1 to brown at light, N joined with other blue in plastic terminal block goes to blue at light, E from the earth terminal of back box goes to earth terminal at light.
