Hi All
About 3 weeks ago my central heating fired up in the morning and tripped the RCD/Main Switch on my consumer unit, and it has done it everytime I have tried to fire it up since. (Notice how I'm only doing something about it now is starting to get cold!!
) Upon reading various posts on this forum I have decided it is probably the pump. To test this I removed the Neutral wire on the pump from where it connects to a complicated looking junction box (technical!) next to my hot water tank. The boiler now fires up and runs no problem (Is it dangerous to run it for a long period with no pump running?) When I place the wire back on, the pump runs for about 10 seconds and then the electrics trip again, plunging me into darkness - fortunately my consumer unit is in a sensible place to reset!
So have I diagnosed the problem successfully?, or is there anything I might be overlooking? I have checked around for leaks but cannot see anything unusual.
If it is the pump this raises many more questions:
Are they all standard?
Do I have to replace like with like?
How much should I expect to pay for a new pump?
Is this something that would be easy for an amateur and his Dad (who has done quite a lot of plumbing before) to replace or am I better off getting a local tradesman in?
How much is a fair price to supply and fit a new pump?
Hope someone out there can advise me - sorry for so many questions.
Rob
Rob
