Replacing a fireplace
15 Nov 2003
I have just bought a new fireplace and want to fit it myself, has anyone attempted the same? If so what are the pitfalls. All help greatfully received
Need more info,do you mean fire surrounding or insert type etc...........
If it a surrounding,they are pretty straight forward with mounting brackets into the wall,should come with the instruction and if it the insert type then it a difference ball game as it require fire & safety regulation which you can't do,only the specialise company.
Thanks for replying so quickly, I have an old tile fireplace at the moment with concrete backing. The new one to replace it is a metal fireplace with tiles running down the sides with a slate hearth and wodden surround. I also need to replace the fire brick which i believe is a 16" single unit.....
