Replacing a "magic corner"
25 Feb 2012
Middlesex
I'm thinking of buying one of these to replace a similar one that has broken:
http://www.hafele.co.uk/shop/p/kitc...er-unit-for-cabinet-width-1000-mm/90828/10140
Is this a good make? Worth the £150 or so it will cost?
Also, what level of difficulty will I face fitting the thing? The one I'm replacing is similar but a different make so it won't be a case of re-using the existing holes. I'm a semi-competent DIY-er but certainly no expert.
Hafele is a good make IMO, very robust.
Fitting can be complex, especially for that sort of unit. Give it a try :)
good bits of Kit now
they went through a bad patch around 4 year's ago with a bad set of bearings but that's all sorted out now
The instructions are good and you should have no problem fitting
I have only fitted Cooke & Lewis corner units which work fine. They came with a printed sheet which shows where to drill holes. It does look complex when you first take it out of the box yet simple when it's all in place.
