I am replacing an outside security light fitted with a PIR with pretty much the same fitting, only new and after disconnecting the old one, I found four wires, red, blue, green/yellow and a plain yellow, which I believe indicates a three-phase supply...? Not being terribly knowledgeable about that set up, can someone tell me how to wire the new fitting which is obviously asking for the newer live brown, blue neutral and the green/yellow earth? I've seen a wiring diagram that has the yellow to live and the red to the spare, is that correct? Thanks in advance!
I have rewired exactly the same as before but the light does not work, Any suggestions. Thanks
Read more: https://www.diynot.com/diy/conversations/wiring-in-pir-light.34604/#ixzz64nsMKxDQ
