replacing a suspended wooden floor and joists
haf
7 Oct 2005
Birmingham
I've just moved into a 1930's detached house where the ground floor is wooden (really old planks) and about 18 inches above ground. Basically the whole downstairs is freezing and doesn't really warmup. Also my survey stated that the joists had some sort of infestation and the whole lot had to be replaced. So having negotiated a discount on the house, I am now looking into doing the work myself. I have tackled most DIY jobs but this is my frist time doing a complete floor. So I am looking for some documentation around how to tackle this job and can't find any 'guides'. Any pointers appreciated as I like to do quite a lot of research before tackling a large job.
Take up your existing floor boards (wall skirting boards first) and note how the joists are supported. Generally, they will be hung on hangers or fixed to a horizontal wall plate (normally wooden; might be infested too) In smaller houses, the joists can span the whole house, with dwarf walls for support, where needed, and support interior walls. If this is the case, you will have a major project on your hands. If your lucky, the joists will be supported at each end only and not have any structures supported by them. If the structure supporting the joists is in good condition, you will only need to either re-inforce the existing joists or replace them. Re-inforcement is achieved by sistering, whereby you bolt a new joist to the old joist at each end and independently fit the sister joist to the supporting structure (joist hanger or wall plate). The sister joist should stand proud of the old joist and take all the weight of your replacement flooring (chipboard is good if you are laying laminate or carpet). You must kill the woodworm before you put the new wood in there.
