    Dismiss Notice
Replacing Aqualisa Aqua valve
Discussion in 'Plumbing and Central Heating' started by ChloeRadshaw1, 15 Sep 2020.
  1. ChloeRadshaw1
    ChloeRadshaw1
    11 Jun 2013
    137
    Thanks Received:
    8
    London
    Country:
    Hi
    I posted on the previous thread and we have decided to just replace the shower mixer as it is too old - The problem is we want something that will fit the existing cutouts of the aqualisa so the no holes or alterations are needed
    I have a quick look on toolstation etc but I could not find much - Does anyone know which showes would have the same cut outs and pipework positions so I can just swap out
  2. Sponsored Links
  3. muggles
    muggles
    28 Oct 2005
    11,970
    Thanks Received:
    2,540
    Daventry
    Country:
    A new Aqualisa Aquavalve would work...
  4. ChloeRadshaw1
    ChloeRadshaw1
    11 Jun 2013
    137
    Thanks Received:
    8
    London
    Country:
    They do not make them anymore !!! My shower is approx 25 years old appareently
  5. JohnD
    JohnD
    15 Nov 2005
    66,170
    Thanks Received:
    3,587
    Coastal
    Country:
    Cook Islands
    The Aqualisa Colt (round) seems to be the same as the Aquavalve 600 series (with a new name on it) but AFAIK is only available in the recessed version.
    I will go and look on my shelf.
  6. ChloeRadshaw1
    ChloeRadshaw1
    11 Jun 2013
    137
    Thanks Received:
    8
    London
    Country:
    Wow john you are amazing thanks a lot - Does the recessed shower fit into an exposed? i would not mind reusing the housing to keep the shower cubicle watertight and intact
  7. Sponsored Links
  8. Chris_W
    Chris_W
    26 Sep 2019
    3,677
    Thanks Received:
    972
    North
    Country:
  9. JohnD
    JohnD
    15 Nov 2005
    66,170
    Thanks Received:
    3,587
    Coastal
    Country:
    Cook Islands
    Here we are. Aquavalve 900, surface mounted, including the plastic shroud. New, unused, boxed, old stock. You can have it for £120
    Note that this one has a pressure balancing cartridge, and a single knob that goes off/on cold/warm/hot
    I have one on a Vented Cylinder, and put one in my friends house on a Combi. Pressure balancing means it compensates if, e.g., someone turns a tap or washing machine on, and the pressure fluctuates.
    AFAIK it has all the bits, but I would have to go through the parts list to make sure.
    Click photos for full size.
    By all means take advice from others. I would not knowingly rip you off.
    20200915_143153[1].jpg 20200915_143158[1].jpg 20200915_143253[1].jpg 20200915_143441[1].jpg 20200915_143515[1].jpg
    • Like Like x 1
  10. JohnD
    JohnD
    15 Nov 2005
    66,170
    Thanks Received:
    3,587
    Coastal
    Country:
    Cook Islands
  11. muggles
    muggles
    28 Oct 2005
    11,970
    Thanks Received:
    2,540
    Daventry
    Country:
  12. ChloeRadshaw1
    ChloeRadshaw1
    11 Jun 2013
    137
    Thanks Received:
    8
    London
    Country:
    Thank you so much.
    Is this a like for like replacement with no cuts outs or drilling required. Does this take 22mm pipe work or does it have to be reduced
    it would also be super helpful if anyone can confirm the width of the pipes on my aqua Lisa. Is it 150mm because if it I can simply buy a new mixer shower and slide it on. It it needs elbows and reducing it makes the job much harder. Of course I can use compression fittings but it’s just awkward in an enclosed shower cubicle
Loading...
Share This Page
