Hi all
I need to replace one of my bath flexi supply pipes:
Would this do the job: http://www.screwfix.com/prods/96407/Plumbing/Flexible-Hoses/Flexible-Tap-Connector-15mm#
I've also seen these 'easy fit' ones: http://www.screwfix.com/prods/35300...t-Flex-Tap-Connector-22mm-x-x-300mm-Pack-of-2
Which should i go for? How exactly do the easy fit ones work?
Also once i have turned water off at the valve, do i just hold nut 1 in place with a spanner and turn nut 2 to loosen it, any need for PTF tape when fitting the new one ?
Cheers for any tips
Pete
Cheers for any tips
Pete
