Hi
I am replacing bathroom fan, only have neutral and switched line supplies, don't have permanent live. Can I use fan with timer, leaving permanent live terminal blank; to be used as standard fan?
Yes, it will work as a standard fan, but no timer feature. To use the timer, you do need that permanent live, which you should be able to source, at the ceiling rose.
Or replace the fan with a 12V one where the 3-core only has to run to a much more easy location for the transformer, and the existing fan cable retained.
