Replacing electric shower with thermostatic
1 May 2006
Wiltshire
Hi, First post here so here goes.
I am planning to fit a new shower enclosure, with thermostatic shower, in my bathroom, after I have removed the old bath. I would like to use the existing bath's tap feeds for the new shower. The cold is mains fed 15mm dia. the hot is 22mm from a combination tank above the bathroom located airing cupboard (no loft). The height from floor to bottom of the combination tank's cold tank is 1750mm. I guess the shower head will be about the same if not slightly higher. The shower enclosure also has eight hydrojets. The shower supplier specifies that I require a water pressure of 2.25bar.
Question is what troubles am I potentially liable to encounter? Best to find out now before I start!
All advise will be most appreciated.
Thanks for reading
Tony
Explain combination tank, if you mean Fortic then you got no chance.
the 2.2 bar is no good if you cannot supply the volume as well, How much litres per minute do they say
They say 10 litres per minute.
What should be looking at getting to replace Fortic? (don't know if I have one but assume I do).
