- Joined
- 10 Oct 2026
- Messages
- 4
- Reaction score
- 3
- Country
Hi all,
I’m looking for some advice on replacing my existing wireless thermostat receiver with a tado Wireless Receiver X, and I’m hoping someone familiar with this boiler and receiver can help.
My setup:
Current ESi receiver wiring:
The terminals are currently connected as follows:
The ESi receiver’s terminals 5 and 6, which are for OpenTherm, aren’t being used.
The tado app recognises the ESi ESRTP4RF+ but then tells me an additional two-core power supply cable is required. Its instructions don’t clearly explain how to transfer the existing hardwired supply and heating control connections to the tado receiver.
My questions are:
I’ve found the boiler installation manual, which includes diagrams for external room thermostats and programmers, but I don’t want to assume the original installer followed a particular diagram without verifying the actual connections.
I’m happy to provide photos of the receiver terminals and wiring, and any advice would be appreciated.
Thanks!
My setup:
- Boiler: Ideal Logic+ Combi 30
- Boiler GC number: 47-348-66
- Existing receiver: ESi ESRTP4RF+
- New thermostat/receiver: tado Wireless Smart Thermostat X Starter Kit (UK version)
- The existing receiver is hardwired and powered via a wall-mounted isolator switch.
- N: two blue wires
- L: two brown wires
- Terminal 1 (COM): one blue wire
- Terminal 2 (NO): one brown wire
- Terminals 3, 4, 5 and 6 are empty
- Earth wires are connected to the earth terminal.
My questions are:
- Is this boiler and receiver setup using 230 V switched-live relay control, or potential-free relay control?
- Can the existing hardwired supply and wall isolator be reused to power the tado receiver, rather than installing a separate plug-in power supply?
- Which tado terminals should the existing common and normally-open heating control connections go to?
- Does the tado receiver need an L-to-CH COM link for this particular setup, or would that be incorrect?
- Has anyone installed a tado Wireless Receiver X on this exact boiler, ideally replacing the same ESi receiver? Photos or a wiring diagram showing the boiler-side connections would be particularly helpful.
Thanks!
