Replacing Garage Up & Over door with a UPVC unit, need advice please.
Permitted development and Building Regulations are separate, as already said, and this is not a like-for-like swap of one up-and-over door for another.
On planning, you are not in a conservation area, the opening is at the rear and set back, the store is already shown as an unheated store on approved plans, and you are not creating a living room or an internal door into the house. That all helps. It does not automatically mean a large glazed French-door unit in place of a garage door is the same as a normal garage-door replacement. I would still ask the local planning authority, in writing, whether they treat this as permitted development, and mention any condition from the approval five years ago that the front part must remain a store, even if you have ample drive space and no car.
On Building Regulations, the existing lintel staying in place is important: you are not forming a new opening. Safety glazing in doors and low-level panes is the usual concern, and you already intend to have that certified. Option 1, bricking up part of the opening, is more obviously building work. Option 2, a frame on a low plinth with a DPC to match the house, is closer to filling the existing opening, but I would still put the question to Building Control rather than assume they are uninterested. Keep the use as an unheated store, with access only from outside, consistent with the approved plans. Adding an internal door or using it as a room later would be a different project.
