i'm planning to replace pump with similar type. Instruction state the water flow should be in upwards direction. However, if installed in downward direction there should be a venting system below pump to prevent damage.
The pump to be replaced is showing arrow in downward direction, but I can't see any means of venting the system.
Should I ensure that the new pump is installed with arrow in downward direction. If I do this, all the writing around the central vent shaft will be upside down.
Advise welcomed.
Thanks.
Advise welcomed.
Thanks.
