Due to structural movement in the house, it's been necessary to remove a couple of door frames which were twisted and knackered and replace them. The linings were floor to ceiling with the top panel plastered. So far I have cut the frame away to just below the plastered section and was hoping to get a carpenter in to install the new frames but he's moved!
I don't mind doing it myself but would appreciate any advice. Do I need to find floor to ceiling linings and in fact are they available?
The original linings were about 90mm (side with rebate in) by about 60mm. All the linings I have seen so far are much thinner and therefore I will need to pack the lining out against the brick/blockwork. Any tips?
I was going to fix the new linings with frame fixings (the long plastic plugs with screw in screws (10 x 100mm) does that sound about right?
I've hung plenty of doors but never fitted a door lining and it's one of those things you can't seem to find instructions on, any advice greatly received.
