Some of the upstairs joists in the kitchen below the third bedroom are rotten and some have bowed. Some of the joists are sitting on a wooden plate which has rotted and sits between the layers of bricks. I need to replace part of the plate but was it the best way of doing it?
Should I just remove all the joists and redo the entire bedroom floor? If so how do I do this - anchor bolt a new plate to the brick work and use jiffy hangers to hang new joists - if so what size plate / joists / anchor bolts / spacing etc.
Another problem issue is on opposite side of the kitchen - it seems the previous had double glazing installed but there is only a wooden lintel above the window frame. Above this there is the wooden plate which spans the length of the wall and supports the joists. Also above this is a stud wall which is further causing a large dip in the upstairs floor? How can I fix this? Should I rent some acrows, remove the joists, jack up the plate and then insert a concrete lintel?
Lastly it seems that the wall of the extension has come away from the rear of the house? Should I be concerned by this and what can I do to fix it - will sand and cementing over it be sufficient? I'm intending to have a boiler installed on that wall.
Thanks in advance.
Thanks in advance.
