Replacing light switches
21 May 2003
Good afternoon all.
While in the process of decorating our hall, I want to replace the old light switch covers with new ones. I have a load left over from a few years back which were never used, but am not sure if I can use them.
The ones that are in place all have three connections - one at the top, and two at the bottom, and have a wire connecting into each.
My new covers have four connectors, two at the top and two at the bottom, and are described as "1 gang intermediate switch". The connectors are marked L1 L2 L3 L4.
Am I able to use my covers in place of the existing ones?
Yes you can use an intermediate switch to replace your existing 2 way switches.
You need to link the top two terminals together with a piece of wire, and that effectively becomes your common terminal, and the bottom two are effectively your L1 and L2 terminals
Thanks RF Lighting.
To confirm...
a) I link the top two (currently marked L1 and L2) together, and then also put the existing top wire into either one of these so that it's joined with the link?
b) I put the existing bottom two wires into the similar positions on my new switch, marked L3 and L4?
Absolute tosh RF...
you don't need to connect the 2 top terminals together.. that defeats the object as both output wires will be live all the time regardless of the switch position..
just use 1 on the top and 2 at the bottom.. doesn't matter which top one you use..
ColJack said:
Absolute tosh RF...
Haha! That's what's great about internet forums... no one agrees!
Now I have a choice to make, so any other thoughts appreciated!
