I am really lost.
I have replaced all the light switch front plates in my new house( they were brass and the lighting circuit isn't earthed!)and they work fine, except for this one.
Its a 2 way 2 gang switch that is only being used as a 1 way switch. It was wired in the following way.
All wires are red.
Common to common on each switch then one cable to L2 on switch 1 and a piece of cable not attached to anything from L1 to L1.
Now only one of the switches works and the other doesnt. I swapped the L2 on one switch to the other, then that worked and the other didn't?
The other switch that I replaced that was 2 gang and had 4 cables yet this one only has 3 (2 commons and L2)
I'm a complete novice when it comes to electrics and I can't find anything like this using search on these forums. Any help would make the last 3 hours of trying nearly worthwhile.
All wires are red.
