If i was to replace or paint my ageing sky dish, if i was to remove it and replace it with a new dish is there an easy way to make sure it's set up the same or would i need someone to set it all again and check the signal? I don't have the equipment for this.
Yep. The cheap meters don't tell you what satellite you're pointing at, but you can get that from the Sky box. Once it's on the right satellite then the meter works fine for doing a line-up.
I'll go with the matt spray finish or a new dish then depending on how bad it is once close up. From what i have read it seems to be ok to remove and refit without altering the signal too much. Thanks everyone.
I recently found out the reason why my newly bought house had two sat dishes, the previous owner was an elderly gentleman and he managed to write off the first dish by painting it (I'm guessing he used some kind of metal based paint) he must have not been arsed to take it down so he just put a new one up.
