Replacing Quarry Tile Floor With Screed / Concrete
6 Dec 2008
Nottingham
I have a 1930's end of terrace house which I am currently renovating. The kitchen floor had broken quarry tiles laid on an sand and earth. I have currently dug this out to about 7"'s.
I am not looking for something super tough, just something that is stable and within a good budget / easy and quick to lay. The total area to cover is about 24m2 and I would like to be able to lay tiles on it as soon as possible
Can I put down for example
5cm hardcore
2cm blinding sand
5cm Jabalite insulation
DPM
and then a 5cm screed?
Some people I have spoke to have indicated this would be ok and it is certainly more solid than what was previously there.
Can any one advise me on whether this is acceptable / a recipe for disaster. Or alternatively tell me the proper way to do it..
Kind regards
RealityTested
just lay a 100mm trowelled concrete slab as opposed to screed.
it may mean digging a little bit more off or forsaking a little hard core or blinding, but 100mm slab, is a minimum.
Thanks for your reply noseall.
I wonder however if you or someone else could clarify
1) Why to use a concrete slab over screed (I assume it is to do with how strong it is?)
2) What the order / minimum depths are for each layer (ie Hardcore, sand, insulation, DPM and slab?)
3) What Kind of insulation you would recommend
4) Also if a quick drying concrete is used to make the slab would it be possible to lay tiles on it say 3 weeks later?
