Replacing radiator
28 Apr 2008
Birmingham
Im doing a little diy in the bathroom and have removed the radiator to remove the wallpaper etc and got thinking about replacing the radiator with either a new one or a towel radiator.
Measuring the gap where the old radiator is fitted is 29", however at most radiators only seem to be 600mm wide.
Is it possible to fit a new radiator without having to move the pipework coming from under the floor? :oops:
Rob
Edit corrected typo - (600mm)
yes you can fit a new radiator and if slightly smaller use radiator tail extensions.
towel rail would need to alter pipework and best done under floor level
