The facts;
My property is about 3 ft lower than my neighbours
There is about 5ft height to the top of this wall on my/low side
The foundation concrete is at ground level and will need redoing
The wall is approx 28yds long and is stepped as it also runs downhill away from the house.
It's amazing it is still almost upright as it is 9" breize block to ground level and 4"above
I plan to rebuild this so a few guidelines before I ask for quotes would be welcome.
What do I need, 12" below and 6" above?, it will be either concrete block , reconstituted stone or even natural stone
A weeping drain at foundation level that naturally drains from the property?, as at present there is just on 4" pipe running through the wall at the top.
And I know it's impossible but based on material choice, just how expensive is this going to prove.?
Just want to ensure I am getting a good job and the spec is correct,
Cheers
Cheers
