Replacing rockwool/fibreglass insulation with kingspan
7 Apr 2010
Glamorgan
My attic is fully boarded - tongue and groove over 4x2 joists. The previous owner has laid 10" rockwool/fibreglass over the boards, making the roof space unuseable.
I thought to remove the fibreglass, replace with Kingspan or similar and board over the top, creating a useable space, but having equivalent insulation, for the EPC when I come to sell.
Does this seem sensible? If so, How do I know how thick the Kingspan sheets should be? Is (say) 50mm Kingspan, foil on both sides, equivalent to 10" rockwool? I can't seem to find the info anywhere?
Cheers.
I have "coolag" now known as celotex aka kingspan(i think :?: ) in my loft 40 mm(its that size because it was free),between the joists and the spars,i dont even have any gaps for airflow :shock: but then again it was fitted back in the day :wink: Works good for me
Thanks. I was looking at 50mm sheets. It does seem quite difficult to find equivalent thicknesses, though.
100 mm of Rockwool has an R value of 2.5
100 mm of Kingspan has an R value of 4
so you would need 160 mm of KS to replace the Rockwool to achieve the same insulation value.
The foil is irrelevant.
I don't know if it makes any difference for the EPC. My experience is ( when renting my house and needing an EPC) that if they can't see it, they simply assume what was legal minimum when the house was built.
This is very much a box ticking exercise with no investigation.
