replacing switchmaster300 with Honeywell st9400c
12 Jul 2012
The old switchmaster 300 that worked as a timer on my gas Rayburn is broken and I want to replace it with a Honeywell st9400c using just one of the channels. At the moment apart from the earth wires,there is the live and neutral feed fro the mains spur, then the live to the ch pump and Rayburn in position 1, and the neutral to the pump and Rayburn at position 2 on the Switchmaster. Positions 3 and 4 are unused. The lpositions of the live and neutral feed are shown clearly for the Honeywell.Can someone please advise me what position (1-4) the live and neutral to the pump and Rayburn should be connected to on the ST9400C.
Wiring connections for Honeywell ST9400c are as follows:-
L
N
1 = HW OFF
2 = CH OFF
3 = HW ON
4 = CH ON
So connect rayburn and pump to live to 4 and neutral to N
Thanks for spotting my mistake Doitail, obviously it should read, connect raburn live to 3 and pump live to 4 with neutrals connected to N. But he says that he only wants to use one channel?
I was trying to figure out exactly what he was trying to do.
I assume the rayburn is on 24/7 and the programmer is for the pump when he wants the heating on. :confused:
Thank you both
Yes, Rayburn oven is on most of the time with its own on/off/heat setting control on the Rayburn. The ST9400C is just as a timer to control the central heating on the Rayburn and pump.
Thank you both
Why not buy another timer @ a fraction the cost, or do you have a honeywell already.
I have just tried this. The ch pump comes on on the Heating Channel but the boiler comes on on the Hot Water channel. Should the Rayburn live go to position 4 (- with the pump live)?
The Rayburn should have a permanent live.
T4 just brings the pump on.
Does the Rayburn do a hot water cylinder as well
Yes, the Rayburn cooker/oven heats the water too. There is an ?indirect circuit which is linked to the central heating system and this works on gravity if the central heating is off.
Thanks for your help.
