    Dismiss Notice
Replacing very old light switches
Discussion in 'Electrics UK' started by PoppyLane, 5 Oct 2013.
  1. PoppyLane
    PoppyLane
    22 Sep 2012
    16
    Thanks Received:
    London
    Country:
    Hi
    I have painted the house but realise that the old light switches look dirty and dated. I would like to replace the light switch panels only and not the box as it will mean messing up the paintwork. My friend says that a whole box will have to be installed as the sizing is no longer the same and new switches screws are measured slightly different to the ones I have. The house was built in the 60's. I'd be very grateful for an opinion. Thanks. PL
  2. Sponsored Links
  3. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,456
    Thanks Received:
    4,199
    Retired to:
    Country:
    Portugal
    I don't think things have changed much since the sixties (although we did think it would) as far as switches are concerned.
    Difficult to tell what you have from here, though.
  4. Iggifer
    Iggifer
    8 Sep 2011
    4,637
    Thanks Received:
    587
    Warwickshire
    Country:
    my house was built in the 50s and until recently I still had an original box (house was rewired in the 90s but they left one original box for some reason(
    No issues with changing faceplates for modern equivalent, sizing is all the same, I think you have to go a bit further back to find odd sized boxes, for which you can get adapters for anyway
  5. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    If you painted the walls, I hope you took the switches off, not just painted round them.
    Before you change any, read the Wiki articles on lighting, so that you know how they are wired, and how they are labelled - this is particularly important for 2-way and 2-gang switches.
    And don't remove any wires without making a note of exactly where they went.
    Will you be sticking with plastic switches?
  6. Iggifer
    Iggifer
    8 Sep 2011
    4,637
    Thanks Received:
    587
    Warwickshire
    Country:
    I HATE it when people do that, they invariably get more paint on the switch than the wall too and it's me that looks bad when the switch doesn't come off perfectly
    That being said, I was asked to change one recently that was literally flush with the newly plastered wall, it was an old Volex beast so not exactly a slimline switch, so a nice thick coat of plaster round it. I politely declined to do it
  7. PoppyLane
    PoppyLane
    22 Sep 2012
    16
    Thanks Received:
    London
    Country:
    Yes, I'll be sticking with plastic switches.
  8. JohnW2
    JohnW2
    28 Jan 2011
    48,630
    Thanks Received:
    3,189
    Buckinghamshire
    Country:
    ... but remember to keep and use the old screws, which are likely to be BA rather than metric!
    Kind Regards, John
  9. PoppyLane
    PoppyLane
    22 Sep 2012
    16
    Thanks Received:
    London
    Country:
    UPDATE: All switches have been successfully replaced - we used the old screws which was an invaluable piece of advice, as, indeed was all the advice from you all. Many thanks to you all for your helpful responses. PL
  10. Sponsored Links
  11. JohnW2
    JohnW2
    28 Jan 2011
    48,630
    Thanks Received:
    3,189
    Buckinghamshire
    Country:
    You're welcome. Glad it's all worked out!
    Kind Regards, John
  12. sparkwright
    sparkwright
    20 Aug 2009
    8,780
    Thanks Received:
    1,102
    Dorset
    Country:
    Remember to keep the new screws.
    If you get a 3.5 mm re-threader tool (very cheap from electrical wholesalers) you can easily re-thread the holes and fit the new screws.
  13. 333rocky333
    333rocky333
    12 Jan 2008
    8,425
    Thanks Received:
    902
    Essex
    Country:
    I recall The old thread was larger so dont think threadings an option
  14. JohnW2
    JohnW2
    28 Jan 2011
    48,630
    Thanks Received:
    3,189
    Buckinghamshire
    Country:
    Indeed, 4BA is fractionally larger than M3.5 (about 3.6mm IIRC). So, if it's a surface box (with threaded inserts), attempting to re-thread as M3.5 would not really be on (even if it seemed to work, screws may well not be very secure). If it's a metal box with a 'lug', one could distort (squeeze) the lug first and then tap M3.5, but that would, again, be somewhat iffy.
    The OP has used the old screws. If he really wanted to change to 'shiny new' ones, I imagine that if he looked around (ebay?) it's probably still possible to find suitable 4BA screws.
    Kind Regards, John
  15. sparkwright
    sparkwright
    20 Aug 2009
    8,780
    Thanks Received:
    1,102
    Dorset
    Country:
    Missed that. Going by most old imperial boxes, have been able to re-thread successfully to accept new 3.5 mm screws, but if the holes are larger then of course it can't be done.
  16. JohnW2
    JohnW2
    28 Jan 2011
    48,630
    Thanks Received:
    3,189
    Buckinghamshire
    Country:
    I dare say that it can be 'done', but you'd probably be threading only into the 'tips' of the 4BA thread, hence pretty tenuous/iffy.
    Kind Regards, John
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
