Could someone possibly tell me what I'm looking at in this photo and if I can do what I hope I can with it? http://imgur.com/eYWwAnZ
Obviously it's a smart meter for a second feed into my house intended for a downstairs toilet only. I'm replacing the toilet and renovating. So I need to replumb from the supply to the cistern. The thing is just too damn high though. I really want to box in the meter with a box that fits under the cistern, but with the pipe coming out of the top, that's not possible. I'm hoping I can actually just remove the valve on the side instead and affix a new pipe directly there? I've verified that the blue tap controls both in the same way, so all seems to make sense, but for one thing, I can't shift that valve on the side. Should it come off with enough encouragement?
If I can put it there, then I can just shoot a pipe right across under the cistern, take it up to there and also then through the wall to a hopefully rehomed washing machine. What fixtures should I then need to connect to a regular copper pipe? I've never done any plumbing like this and especially as it's all such a limited system and so visible, i'll be safe just using 15mm copper piping and compression fittings.
TIA
Chris
TIA
Chris
