I have a Megaflo unvented hot water cylinder, which is indirectly heated by a condensing gas boiler. I was going to reconstitute the air bubble in the cylinder and so went to turn off the cold water feed to the cylinder.
I understand that the mains cold water feed to the cylinder should be stopped using the isolating valve that has a small black lever sitting on top of the strainer. However, I cannot turn the black lever as the pipe is securely attached to the wall and this prevents the lever being turned clockwise.
I did stop the water using the main stop cock in the property, which is positioned close to the Megaflo, and this was OK for the short time needed to reconstitute the Megaflo’s air bubble. My concern is that if the cold water feed to the Megaflo needed to be stopped for any longer period of time, e.g. for repair, then I would not have any water in the taps or the toilet.
Is there a Megaflo isolating valve / strainer component that has a lever which turns anti-clock wise to isolate the water feed? If not, then is it worth having the existing pipe work altered slightly to allow the existing Megaflo isolating valve / strainer component to be positioned just further off the will by a few inches to allow the isolating valve to be used? This could be done at the same time as the likely replacement of motorized valve problem, which was the subject of a recent posting of mine.
As always, many thanks for your helpful advice.
Mutley56
Mutley56
