Hello,
I'm looking for some advice on working with and planning a soil pipe's route/construction. The pipes are internal and I cannot move the floor entry point.
The basic requirement is to extend the existing soil pipe upwards so that its vent is no longer on the ground floor (hygiene restriction for our cider house).
The existing orientation of the pipe will hit a joist (and it rises overlapping a window opening which is annoying).
My main question is whether a double branch fitting (see attached diagram) would be appropriate here; the horizontal distance of soil pipe either side will be >1m. What would you do with the unused top exit - fit an inspection cap? I'm looking at a double branch to make the job neat.
Secondly where should I add inspection caps (the proposed position of the vertical pipe would put it in a mini corridor where horizontal access would be tricky - is an inspection pipe before a 90° practical?)
I hope the diagram helps explain and thanks to anyone able to take the time to help ^_^
