I've just had a door installed between the house and the garage, the frame is a standard casing with 25mm stops BUT NO INTUMESCENT STRIPS - is this correct?
There should be an intumescent strip and I've had the building inspector notice that I hadn't fitted it on final inspection. The frame was grooved though and the strip is self-adhesive so it was only a case of sticking it in. I think you used to be able to get fire doors that were rebated for the strip, instead of fitting it in the frame, but I don't know if they are still available.
The grooved frames that I've fitted have had 25mm depth stop but I don't think it's a requirement. The important bit is the gap between the door and the frame so that when the strip expands it clamps the door into the frame. The strips I've fitted have been 10mmx4mm. I don't see why you couldn't groove the door edge with a router and fit the strip into the door(unless someone knows different)
