resetting pir lights
13 Feb 2005
Is there a standard fix for resetting outside pir lights after the power has been off .Thanks.
no.
why is yours stuck permanently on?
if so you could try switching off supply for 3 mins then back on, and wait to see does it go out
it may have also received a surge and is now non functional
I've managed it previously , but can't remember the sequence and on off times. It stays on until reset after the power has been off.
try as suggested first.
some have an off-on-of on sequence to keep them on
Sorted, did a search. Off for 10 seconds,resumes normal working after 1 min.
which is what i said, onl i said off for longer (to be sure) but glad its sorted
