Hey everybody!
Well i would be very surprised if a question like this has appeared on this forum so for my first post ill share with you this dilema i been going through!
Anyway i play an instrument called the Dhol drum ( www.dholfoundation.com for more information), it is basically a wooden barrel with to drum heads either side, a thin treble side and a thick goat skin, which are both beat with 2 sticks.
Dhols are usually made of either Mango tree, a more dence rosewood. And are hand made, or carved out in india making everysingle one unique!
The bass is fastened using rope which is easily adjusted with the tention and The top end is fastened to the drum using some hooks.
From drum to drum the bass sides usually sound the same but top ends vary in sound BIG TIME.
Now the best sounding top ends (or treble side) ring and resonate at all different pitches depending on how much u tighten them, but in reality its very rare to get such treble sides, most of them sound like your hitting a pan..
i worked out its all due to , the quality of the wood, but most importantly the angle and condition of the wood which is actually in contact with the treble skin itself.
http://download.yousendit.com/23C6BD057D5FE20E
if you visit this link and download the file you can see some pictures of my dhol and the top end as described.
Now having made this discovery i taken my time to tune my dhols and other peoples simply by using a flat fine file and slowly going around the wood trying to keep it flat and at a consistant angle all the way round, and as you can guess its really not easy, infact its frustrating and time consuming and never guaranteed you'll get it right...
At the minute im working on this drum and the top end is in a really bad state, i cant get it level at a consistant angle at all but the drum is of highest quality of wood so i have to get it right!! another problem is i keep fileing away at the shell and its starting to get narrow so i need to think fast n make sure i get it right.
i need to be able to obtain a flat consistant edge all the way round the end, at a consistant angle...
anyone have any suggestions on a tool, or the best way i can achieve this? i need the drum skins to sit flat on the wood...
thanks alot! sorry about the essay, hope someone can help! if you need any more info, just ask
Tarnjit
Tarnjit
