M
munchingB
hi all
i have put 9 holes along a 3600mm clunch wall which i will be filling with resin and threaded rod to take a 6x2x3.6 wall plate.
just wondering very quickly if someone is about to advise on the way to do this?
i dont want to embed the studs in the wall and slip the wall plate on to find out that all the studs sit squiffy and the plate doesnt go on.
is it possible/is there time to fill all the holes with resin, put up the wall plate(supported by 2 posts at present) and then put the studs in through the wood into the clunch wall?
being a clunch wall of uneven surface my only other option is to extend the length of the nozzle and fill each hole through the wood and into the wall one at a time...but thats another way id rather avoid as i dont fancy losing bits of pipe down my holes and there is still the chance that the first cured hole will not allow alignment for the last
hope that makes sense?
cheers
cheers
