Hi everyone
Ive got an Ideal Concorde WCF, about 20 years old. Rather than go through the financial pain of ripping it out and getting someone to install a new boiler, I need to fix a leak on it....between the two halves of the heat exchanger.
The heat exchanger comes in two parts, and the gas flame goes up between the two parts. In the past there has been a weep on the outside edge where the two parts of the heat exchanger join, and Ive fixed that by cleaning off the loose crud and applying silicon. I now have a weep on the inside, unreachable. If the boiler is to go on being used Ive got to split the heat exchanger and reseal the halves together. That's an easy job, 4 bolts etc... no more difficult than say putting a new rocker box gasket on a car.
Problem: what sealant to use. Ideal's technical line is no help. Too old they say. Can't advise you. So I found fortafix http://www.fortafix.com/products.asp and the technical guy is on holiday ....
Some product choices are:
1. a silicone sealant will go up to 350 C see Fortafix High Temperature RTV Silicone http://www.fortafix.com/products/product-short.asp?ID=88 and
2. they have Fortafix High Temperature Sealant - T.C. Caulking Compound that goes to 1250 C at http://www.fortafix.com/products/product-full-a.asp?ID=84
Any recommendations? While the old sealant is some rock hard stuff, I wonder if I shouldn't be using something which has some flexibility.
Any advice appreciated., it would for example be good to know how hot boiler gas flames are, or maybe there is someone out there who knows a specialist product to recommend.
Thanks.... mark
[/b]
Thanks.... mark
[/b]
