- Joined
- 3 Feb 2025
- Messages
- 3
- Reaction score
- 0
- Country
Apologies for the long title but wanted to highlight the difference from a standard retaining wall foundation question. I've gone through nearly 10 pages of posts to try and find an answer but i've been unable to find an answer.
We have a two tiered back garden and are looking at replacing the retaining wall as it's crumbling in parts. We also have toddler in the house so want to make this tier a bit safer for her to be playing in come summer. The current wall is only to the level of top part of the garden and is around 550mm in height. In order to make it safer though we're planning on making the new wall around 1200mm in height from the bottom part of the garden so the top part of the garden will now have a 650mm high wall.
So my question is, what size foundations should I use? I've read the recommendations for foundations of retaining walls of various sizes but while it's going to be a 1200mm high wall, it's only retaining for the first 550mm. The rest is simply a acting as a standard garden wall as it's above the retained part. So to use foundation recommendations for a "1200mm retaining wall" seems overkill but it does still need to withstand someone leaning on it or a toddler being crazy.
For extra context, I was planning on using concrete blocks and facing bricks with ties on the lower part of the wall to create a double skinned wall that will look nice from the lower part of the garden and then switch to double skin of facing bricks when it gets above the retained part so it then looks nice from the house and the top part. The wall will be stretching around 8 metres in length across the garden and there will be some pillars added where the steps will be placed.
Thanks!
Thanks!
