Retaining wall
3 May 2006
Aberdeenshire
Hello,
I was looking for some advice on building a retaining wall in my garden and would appreciate any comments or help you can give.
I am going to be building the wall with 7n concrete blocks and was wondering if i should lay the first course blocks on their side and then two normal courses on top which would give a 15mm gap or if i could just lay two courses and have a 50mm gap to enable me to use my bricky tool. I would then fill the gap with concrete. as attached
The height of soil to hold back is 750mm so i was going to have a 200mm deep and 500mm wide foundation with the top of the foundation 150mm below the lower ground level. This would then give a total retained height of 900mm. Would it be a good idea to build a deeper flange into the foundation to help prevent slippage or would this be a waste of time?
thanks very much
Trevor
a standard 9" wall will be more than adequate. you could bond the blocks with alternate courses laid flat if you wish.
150mm projection beyond both leaves will suffice.
lay the foundation a little bit deeper or until all the fertile stuff is gone.
thanks noseall appreciate the advice. I will lay blocks flat on alternate courses and dig deeper foundations.
thanks
Trevor
