EDIT - TITLE SHOULD SAY 'CLASS 2'
I've got an old and dated balanced flue gas fire on an outside wall of bungalow as there is no chimney. The wall is flat inside with no chimney breast or proper fireplace. I wanted to replace this with something like a limestone fireplace and modern b/f gas fire.
However, we're thinking of building an extension the other side of the wall from lounge where the b/f vents to outside. As the wall where the gas fire is the only one in lounge where fire can go and I'm under orders that only a gas fire will do - looks like the only option is to have some kind of flue going up to roof.
As it's a bungalow, I'm thinking either class 2 flue or precast. Is it possible to retro fit a class 2 flue or precast? I could either build a fireplace with breast on lounge side, or poss go through wall behind fire into new extension other side of wall and have flue going up in new extension. Poss boxed in behind a stud wall.
Any thoughts appreciated as to whether it's possible and least costly/disruptive way of doing it.
