Denmans used (uses) GE MCBs but branded as their Steeple range.
They are available, new.
They were also known as Vynckier and are identical.
I spy an eBay seller has 20A GE ones, new.
Did you not see this?
http://www.ebay.co.uk/itm/GE-STEEPLE-SECTOR-SERIES-E-TYPE-B-MCB-CIRCUIT-BREAKERS-/390858912301![]()
Write and ask them why they have made an appliance which is so poorly designed and/or constructed that it needs to rely on the circuit protective device, which is not there to protect appliances, in order to be safe.This is the model I need, it's for a AEG 3.5Kw single oven, the manufacturers call for a minimum of 15a and a maximum 20a
Are the plug-in Wylex breakers a match?Oh, a mini trip.
You'll be very very lucky to get a new one of those.
Is it definitely a ge fuse board or is it a wylex board with GE breakers in?
