HI,
I've got an old victorian house to sort out and one of the major jobs is sorting the floor, in some rooms I have suspended wooden floors on rotten joists, in some I have flooring bricks laid direct on earth, in some I have old concrete pads (no DPM) and in one room flags laid on earth.
I'm fairly lucky that the building is long and uniform in size (4.1m by 50 for the front half, where I need the new floor) the outside long front wall and two end walls are 3 solid bricks thick, (no cavity), the foundations are a good 3ft of laid brick work in the ground on top of limestone sets, and the 'back' wall (or middle if you consider the whole house) is 2 foot thick solid brickwork....
To sort out the floor with good ventaillation, insulation, UFH and DPM, I plan on ripping the floor out in stages down its length and replacing it with block and beam, 100mm kingspan, DPC and 75 mm screed with UFH.
So, any thoughts? - has any one actually retrofitted B&B before?? what about sleeper walls and foundations, and advice on size? and how should I make connection with the four walls, (or should I put up a new inner skin with insulation inside on 3 exterior walls, what about the back wall, how do i connect with that?)
All your thoughts and points gratefully recieved, has any one retrofitted B&B before?
Cheers
Andy
Cheers
Andy
