Hello people
Hope u can help me having problems with central heating .boiler fires up for about 10 seconds then goes off then back on and off continually.
I have read some suggestion with regards to the pressure switch and the silicone tubes going to the fan. I have looked at the pressure switch and it only has I tube coming from it and this does not attach to the fan it just hangs down ,felt round fan for any nipple that it might have came off but there is none .
Fan does work ok .also if the pressure switch was faulty would this not effect the hot water? Which is ok most of the time but doe have same problem occasionally
Cheers jim51
Cheers jim51
