- Joined
- 3 Jan 2009
- Messages
- 3
- Reaction score
- 0
- Country
Hi, I am a new boy here and I am 55 years old.
...I have started trying to maintain and repair computer bits and pieces and have repaired some 15" LCD monitors. I enjoy what I am trying to do but I have very little experience with these devices.
I saw some interesting posts after searching the internet for help and I have a question so I registered here tonight.
I want to rewire a power cable that is used with a Japanese ThinkPad power adapter which has the same power specs required for devices used through NZ power points.
I have since removed the 3 pin power plug to the wall socket from the cable and find there is 2 black wires and a green Earth wire.
Figuring out what to do with the earth wire is easy but what about the 2 black wires. Some people say it does not matter but someone says one black wire may be neutral and the other may be phase.
Here is a photo at Image Shack of the end of the cable showing the ends of each wire in the cable and the plug to the adapter and the removed Japanese power plug.
One edge of the cable has 3 lines and the other edge of the cable is rounded and smooth maybe giving someone a clue as to which wire is neutral and which wire is phase.
The cable and the removed power plug and the figure 8 plug are running in the same direction in the photo (smooth edge & the edge with the 3 lines on it) the smooth edge is on the left and the 3 lines on the right looking at the picture.
By nickleboms at 2009-01-03
I am sure now I can just cut the power plug that does not fit the wall power socket and replace with a NZ power plug but which black wire should go to which power plug pin.
...I would love some advice...
[/code]
[/code]
