Thanks for the replies, I disconnected the 3c & earth from the extractor unit (earth wasnt even connected just cut back!). I have run a new length of 2c & earth to a spur switch in bathroom cupboard, from there through wall into a socket in next room.
I have connected the new wire live and neutral in the terminal block in the front of the extractor (however, there is a thin 3c type yellow wire in the extractor terminal block also, which since removing the original 3c & earth now has nothing connected to it. (i noticed another twin and earth running from this terminal block also from the live and neutral, apparently powers my spa bath, as this stopped working when i switched off at the new spur.
anyway, extractor still doesnt work, anything to do with the yellow power wire at the terminal?, should i have run 3c & earth from extractor to the spur switch instead of twin & earth?
